veyrongatti
- Aug 3, 2011
I just bought these today and love the sound but simply cannot stand the sibilence
If you bought them new, then you should have a pair of Comply's in the box to try....as mentioned above, they will help with the harsh highs.
but the complys make them lose abit of highs idk i really like them but i cant listen to classical with the sibilence
I got the UE700 for a bit now and I have no issues with sibilance.Which classical songs do you listen to?
Hey, what is your source. On ipod and iphone, u should download the 2$ app called EQU. It will allow you to customize your frequency curve and cut out some of the treble to prevent sibilance. Although i dont think it will help much, the preset eq treble reducer might work. But again, you still shoudl try to get use to it.
