Hey folks, I've decided I will bite the bullet and get the Hunter. Is there any reason for me to also get the master 6?(looking at you indie gogo bundle). Otherwise I'll probably get two airs instead of the bundle.
I'm still not sure why the two need to be exclusive. There's no reason someone couldn't design a system that's fully replaceable and terminates at the Y. You get the advantages of both at that point, the flexibility, customizability, and ease of mind of a fully replaceable cable, as well as the convenience and quick switching between multiple tasks that terminating at the Y gives you. Because 99% of the time you're going to only change the lower portion of the cable, you don't really need to worry about wearing out the connectors on the IEMs.
I actually thought the same, if both are replaceable you will most likely just wear out the bottom part but still leaves you the possibility to change the other cable but i understand that it could defeat their (Trinity) purpose with this planned change.
Unless it has changed recently, the PM6 was designed using 2 x DUAL BA drivers and the Hunter was using 4 x SINGLE BA drivers. Both dual and single were from Sonion of course so the sound quality is probably excellent in both cases, but I suspect there are more tuning options when dealing with 4 pipes instead of 2.
I totally agree. A fully replaceable cable that also terminates at the Y split is what i would like best. If it's already fitted before shipment than people don't screw up the connection placing the cable incorrect.
I think that was what we all initially assumed, but a few months back Bob stated that they both use the same dual BAs. At least I think I remember that.
(1) Can i use the 2-pin balanced Silver Litz cable i just ordered for Master 6 as well (as was my intention)? Otherwise i would have to cancel the order.
(2) What is the new expected shipping date for Master 6 preorders? I assume not December anymore?
"There are no major changes to the Master 6 and Hunter other than we will be using the industry standard recessed 2 pin set up rather than our own."
I ordered the Litz to go with my Master 4 + 6. But it seems they have different 2-pin connectors.
I just don't want to buy a separate balanced cable for every single IEM (have the Atlas too...).
So now their is a confusion about the configuration between PM6 and Hunter's tuning +dd+ba drivers specially Hunters buyers want to know how can their hunters will be sound wise superior to PM6 in case the hunter has 5 drivers per side and pm6 has 6 same drivers per side,
Bobtrinity please please please clear this confusion , , , , ,
I'm wondering this as well, since he had been saying the tuning will be the same between the two all along, but Hunter was supposedly getting better drivers. But we seem to be getting conflicting info and it is hard to keep track of all the changes. Not a huge deal, The litz cables and premium materials alone make the Hunter worth it over the PM6... Unless it actually ends up sounding worse
It appears that you are correct Jeff. I went back and found a post from Bob:
M4 uses same drivers as delta v-ii and has been stated a couple of times in this huge thread so easily missed.M4 is 2 x dynamic and 2 x single BA.M6 and hunter both use 2 x sonion dual BA's in different states of tune. So m4 and hunter share absolutely nothing in common. Hunter uses a new way of tuning a ba rather than the typical damper on tube system employed by 99% of the industry and as such don't wish to reveal too much at this stage.
@Bobtrinity, I'm not sure if this has been covered before but what exactly is the vectoring system in the Hunter? Also, will there be tubing used to guide the sound to the nozzle in the Hunter?
If you check the description of item on trinity website they stated as pm6 carries 2 dual ba and hunter 4 balance armatures which honestly I don't understand properly ,
