normally i would, right now i got my DIY silver gold, piccolino on hand, and expecting the silver widow and silver peptide litz by the end of the month
but still, i would try my luck and wait for a second hand when the price is down to below $400
Balanced cable from Tralucent?....it's already available, you just have to request it...the difference is just the plug.
The AK240 will have a totally odd-ball 2.5mm jack so that will be a real challenge since I have my doubts that a High Quality 2.5mm plug even exists? And we are not talking about a magnetic steel centered plug but a non-magnetic plug in the tensy-weensy 2.5mm size...can you say: "damn....it snapped right-off" ?
Try speak with Mimouille and Tupac. They both mentioned the NT6 having similarities to the 1Plus2. I opted for the SE5 instead due to it being quite different from the 1Plus2 yet being able to compliment them still....
I used to think NT6 sounds very very similar to 1+2. As I get to know more 1+2, I realize they still do have some differences, though they are both bright IEMs.
With cut comply tips on 1+2:
NT6 has more mid body, "density" and forwardness, so 1+2 has less filled soundstage leading to a wider presentation (NT6 is still spacious)
NT6 is smoother and fuller with more instant clarity, while 1+2 sounds a bit thinner and sharper on the instruments/upper vocals.
1+2 is generally a little bit more punchy on the bass with longer decay, while NT6 has reference type of bass which lands with more accuracy and authority.
I think overall 1+2 is easier on ears. I need to rest from time to time when listening to NT6.
Wow seems like nt6 is the way to go.. I will definitely look into it. I love everything abt 1p2, esp it's clean bass and good trebly energy with outstanding sounstage.
I kind of read a lot abt jerry Harvey iems, did any of them has good trebly energy or the warmish typed. Did anyone of them is as trebly as 1p2 or akg3003 or even th900.. Me love bright stuff..
