pepitoaudio
- Jan 25, 2015
Well... This is what I did to be able to register BEFORE TIDAL was available in my country. And you need to use the VPN only for registration. Then, once you get your log-in, you do not need to use the VPN anymore
Well, I'm from outside US and, yes, I registered to Tidal through a US VPN, submited my (non-US) credit card data and have been enjoying the 7-day free trial.
I've been a Spotify Premium user since 2013 and it's such a value for money. Music catalog is vast but not perfect, though. I'm very pleased with the sound quality overall (at 320 Kbps).
So what about Tidal?
I tested Tidal (HIFI) and Spotify (Extreme Quality) side-by-side using my current gear:
-Samsung Galaxy Note 3 (N9005, LTE, Snapdragon)
-Samsung Galaxy Tab S 8.4 (Exynos)
-Apple iPad Air 2
-Bose QC25
-Bose Soundlink III
Yes, I have no true audiophile gear yet. Despite this, some DACs are better than others, and you can spot differences between Tidal and Spotify.
Let's begin with the best DAC, the one inside the Galaxy Tab S 8.4. As it uses an Exynos processor, it probably has a Wolfson DAC. Tidal sounds noticeably better than Spotify in this tablet, whether you are listening to music though the headphones or though the speaker. Period. Better separation and more detailed, airy sound; more ample soundstage. Tighter bass. Even over Bluetooth (not ideal, I know), you can feel the difference.
iPad Air 2: It is a close call, but Spotify sounds better (not by much).
The DAC should play an important role in the results, but I'm wondering if the file format used by both platforms on iOS (OGG, ¿ALAC?) also has something to do...
Galaxy Note 3: The DAC here is pretty standard. It really depends on the song you're playing. Sometimes Tidal it's better, sometimes Spotify.
My two cents: If you don't have relatively sophisticated, high quality gear, save $10 per month and keep using Spotify. Sound is pretty good, music catalog is better, and interface is superior. By the way, I had some issues streaming videos from Tidal, even using a 50 Mbps connection.
I hope it is useful for everyone.
Cheers.
