CrazyRay
- Sep 16, 2004
What I will say is this - I can guarantee that no one who came over to my house and listened to vinyl would leave thinking it didn't sound good
X2!
I count myself lucky to have seen the demise of both vinyl and SACD as serious recording media.
16/44k1 is here to stay. It's as good as it needs to be and no better and a huge fraction of the population recognises that. All these other guys are just being different for the sake of being different, or perhaps difficult for the sake of being difficult is closer to the truth; the prima donna syndrome, it's just a failure to grow up.
w
Hummmm....
You are really missing out on something really special.
What, noise and distortion?
No, a half century of fabulous music... And a half century before that on shellac.
Even in a court of law you get decisions that are described as perverse.
There are enough people out there who delight in being perverse to have revived vinyl production. There are enough people who delight in promulgating a controversy to sustain this argument. Why would that be a surprise? It doesn't make the decision any the less perverse.
w
No medium really matters. It's only a container for what counts.
Then we're fine, because ever since Edison went from brown wax cylanders to shellac, records have been extremely durable as long as your playback equipment is in good repair.That's not true. If the medium will eventually wear out or loses quality over time from playing it, then it's not a reliable medium.
16 bit only has 96dB of dynamic range, and while you certainly would never utilize the full breadth of 24-bit capability or you'd be deaf at 144dB, you can certainly find benefits in a recording that have greater than 96dB of dynamic range (i.e., 100 - 110dB).
My CD collection is about 85% classical, the biggest dynamic range on any of them is barely over 60db and that (Mahler 1, Solti/CSO 1984) goes from whisper quiet in the opening bars to very loud, I'm not convinced you would find many (if any) high res recordings with much more than that, and for rock, forget it. An orchestra may peak at 110+ db but in a concert hall you would be looking at 50 - 60db of that as background noise. I've honestly never heard of a commercial recording with a dynamic range of over 96db, but I am prepared to be proven wrong...
Not if you value your hearing. If you boost 96dB up high enough to be able to hear the quietest sounds, you would be over the line for hearing damage.
Yes, but you will admit they won't last indefinitely. You have a diamond, which is the 2nd or 3rd strongest known material (the others have been developed in labs, the most recent of which can support a weight of 10,000 lbs. with a 1 foot long by 1mm rod if I'm not mistaken) that rubs across the surface of the vinyl, and eventually the medium will lose some of it's information. You don't have that problem with digital, since you can move a file from one hard drive to another with zero loss of quality.
With proper care vinyl will last as long as an optical disk, some of which have been known to degrade over time without even being played. And unlike hard or flash drives vinyl is impervious to magnetism, even the dreaded electromagnetic doomsday pulse
