Just sharing
The Takstar, Technical Pro, Gemini Greathon, CyberX, Qpad Thread
bhazard
- Jul 15, 2013
I have them all except for the JVC, and the HD6000 is my current favorite, followed by the superlux, then pro 80. All 3 are great headphones.
- superlux 681 evo
- takstar hd 6000
- takstar pro 80
- jvc ha-rx 700 or 900
comfort is a concern but don't mind aftermarket mods/pads
semi open or closed budget max 80$ + shipping (im in the eu )
ss23
- Aug 9, 2013
Two questions on the HD6000s:
1) Anyone whose listened to the HD6000s, also listened to the M50s? How do they compare against each other? Is there a clear winner? I've never actually listened to the M50s and I'm planning on buying one as a gift for a family member so could do with some useful insight if anyone's willing to share!
2) Anyone done the removable cable mod? How did it go? I'm planning on doing it so if no one else has, I'll provide details of how it went.
Thanks in advance guys!
MrEleventy
- Oct 24, 2012
I've done one on the HI2050. It was pretty easy.
Noah87
- Aug 28, 2011
thx for that info !!!
one more quick one
in terms of revealing bad recordings wich one reveals the least , looking for the one most "forgiving"
one more quick one
weirdek
- Feb 9, 2012
Here's a quick review for the Gemini HSR-1000 (Takstar Pro 80)
They got around 100 hours of burn-in and I'm running them with the Xonar DG. The only comparison I can make is with the CALs which are pretty decent too. Sadly I don't have any of the more expensive models because I'm always looking for budget cans.
Build quality: These cans don't look or feel like 50$ headphones. They feel sturdy and there's no noise from the moving parts (the CALs have a squeaking noise), the plastic seems to be of a good quality and the aluminium frames speak for themselves. The only annoying thing is the coiled cable, but that's just me.
Score: 5/5
Comfort and isolation: Coming from the extremely lightweight CALs, these headphones weigh a bit more but they're extremely comfortable. The (p)leather pads are really comfy and don't generate too much heat when you wear them for a longer period of time. That being said, the only problem is that I almost fully stretched out the frame to fit my head and I've got a medium sized head so people with bigger heads might have problems. They block most of the outside noise and they pretty much don't leak sound at all.
Score: 5/5
Sound: The best part of these headphones. For the price I paid I still can't believe that they sound so good. I had a chance to try a few 200$ headphones for a short while and I still consider these ones more impressive when you first put them on. The bass on them isn't as punchy as I would like it to be (I prefer just a bit more punch to the bass for some tracks) but they reach pretty low and the clarity is amazing. Mids are also a big step up from the CALs giving a LOT more detailed sound, vocals sound amazing and a bit more in your face which I prefer. Highs are extremely good, you can hear the details but not in a harsh and over-pronounced way and the clarity is also very good. The soundstage is pretty impressive for a closed can and I have no problems hearing sounds coming from different directions, especially in FPS games. All in all if they had just a tiny bit more punch in the bass they would be perfect, but that's just nitpicking considering it's a 50$ headphone.
Score: 4.5/5
I run them on exciter mode through the Xonar DG and they're at least 2-3x better than CALs at a lower price. I guess they can stand up to some higher priced models too.
Score: 5/5
Score: 5/5
Score: 4.5/5
bhazard
- Jul 15, 2013
The HD6000 has that extra bass, and is even more refined in the mids and highs, maybe even slightly more laid back there than the Pro 80. Well worth the $90, and probably my second best headphone I have under my HE-500.
Score: 4.5/5
bhazard
- Jul 15, 2013
Big sale tomorrow on aliexpress, and the HD6000 is currently $83 shipped there at the "Good Buy" store. Well worth it.
pcnoob101
- Jun 30, 2013
Do the HD6000 have a coiled or straight cable?
bhazard
- Jul 15, 2013
pcnoob101
- Jun 30, 2013
Thanks! Just grabbed a pair and will be returning my HSR 1000. Couldn't stand the coiled cable pulling my head.
Canadian250
- Aug 30, 2013
Looking to buy one of the following: HD6000, Pro80 or MDR V6 which is the best overall quality headphone of these three? Thanks for your suggestions.
Note: Amp will not be used
I think the MDR V6 is more of a clinical sounding can, between the Pro-80 and HD 6000 looks like the latter has a more bass and portability. depends really on what music you listen to.
I have the Pro-80 and really impressed with the build and SQ for the price I paid for it.
Canadian250
- Aug 30, 2013
I listen to mainly rock bands such as Oasis Red Hot Chilli Peppers and Coldplay with a bit of rap/hiphop and electronic. I want the headphones to be able to play a wide range of music well. I'm not much of a bass head but I would like them to be able to sound lively when listening to rap.
Canadian250
- Aug 30, 2013
Where is the best place to buy the Pro 80's? Ive heard that the Gemini HSR-1000's are the same I just wanted to be sure before I bought them.
