lan
Videographus Supremus:Makes audio cables using super-advanced materials, like "some clear tape" and "some not so clear tape."
- Sep 4, 2002
So I just got a new power supply, Antec Phantom 350W (fanless) to test against my Fortron 350W (120mm fan). Obviously fanless has less noise but on another note, the sound quality was a bit better. The highs were a bit clearer.
Now I'm not recommending the Antec but just saying these things seem to make some kind of difference sonically. The Antec is too expensive at $199 retail and is fanless which maybe tricky for some systems. I use 4 external harddrives and DVD burner (in firewire cases). My case fans are externally powered as well to avoid electrical noise pumping back into my system from the motors.
Power conditiong and a power cord still makes a larger difference to me than between these two power supplies. I'd like to try a Seasonic next.
