maverickronin
- Apr 5, 2010
CMSS vs Dolby Headphone is often an individual issue because neither is customized to a specific person's HRTF and uses a generic one based on some sort of averaging or modeling. That means one of them could work better for one person and the other could be better for a different person. You'll really have to hear it for yourself to find out.
Since you're on a budget you'll probably be ok with out a separate DAC. A separate amp might help though. If you're just running the Pro 80s from your X-Fi I'd imagine that it has a fairly high output impedance which will make the Pro 80's bass more boomy and overwhelming than it should be. Something like the O2 or the ODA if you prefer a more "normal" form factor with a low output impedance will show you how the Pro 80's bass is really supposed to sound and may reduce some of that messing around with the settings.
Brand new user's massive first post warning -
