sacd lover
- Aug 31, 2002
Must be a refelection.
Gray plates have a reputation as generally being brighter and less refined than black plates .... so go figure???
Originally Posted by -=Germania=- /img/forum/go_quote.gif Nope - both clearly are single square types. Upon further inspection.... The side horseshoe getter Sylvania have plates that are black and the RCA has plates that are more like a dark grey. Both are directly on the Mica. I did find one variance between the CA and the Non-CA marked Sylvania tubes. The one that is not as bright has an extra 1mm x 0.5mm piece of metal coming from the side of the "filament" (the glowing center piece), in the center, at the top. It is far too tiny to take pics of and barely noticible. The CA tube has a slightly shorter overall "filament" than the Non-CA. Otherwise identical. |
