JiggaD369
- Apr 18, 2005
Is there anyone who can match these parts for us?
FlukeII, I was on internet page that you had sended to us...
That workshop is better equipped than my university. Multimeter costs twice than Lovely Cube alone....
Man, in that demand for perfection, you have gone too far.
Hey Flukell,
Are you still going to post the spreadsheet with the caps you tried around the opamp?
There is more to come, I've just been busy with other things i.e. work.
Other things:
- User a Super Beta filter to fed the OpAmp
- OpAmp changes: I like the LME49720, but friends prefer the AD823, NE5532 even! Personally, I think the OPA2134P is a little dull sounding, it's polite, but to me lacks punch, on the other hand the AD823 is more in your face presentation...
- Power Supply mods
- Triming the LM337/LM317 voltage regulators to get the +ive and -ive voltages equal
Yesterday I ordered LME49720HA... I will try it in combination with 2N5087/5088 and matched MJE243/MJE253.
Hi FlukeII, what do you think about stock TO220 heatsinks (in LC)? I think that amplifier is too warm. I mean, I do not believe in sentence "it is A class so it has to be warm". Problem is there is not enough place for bigger heatsink...
Other things:
- Power Supply mods
Quote:Yesterday I ordered LME49720HA... I will try it in combination with 2N5087/5088 and matched MJE243/MJE253.
Other things:
- Power Supply mods
It has to be warm. Because in class A transistors are always open.
Other things:
- Power Supply mods
But I really do not like when it becomes warm! I do not like when transistors are hot (over 60°C) and I do not care about commercial trick "it works best when it is warm". I am sure that class A amplifier can be cold and still operate in A class. Best amlifiers behave in that way, because designers are not trying to save money on the most important thing - cooling. But this minimalistic design just sucks. Small design involves high noise, too much heating and all components in it have shorter life.
I bought a few of these heatsinks: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=280498961521&ssPageName=STRK:MEWNX:IT I also bought a few heatsinks from local store that are higher than those supplied with LC. Because of mimimalistic design I will have to improvise (drill extra holes, etc)...
Output resistors (1W) become brown (I do not like that because they were white as new) and also know that good resistors do not change color, unless they are overloaded), so I concluded that 1W is not enough. Besides, I can not find who made them. Maybe some "Middle of nowhere" company from China? Mills is too big (5W). Riken, Shinkoh are to expensive (5-10 USD each) Vishay is sick (10-15 USD each), Takman (2 USD each) I like more in the signal circuit, Alan Bradley I have never tried... Kiwame 2W are the best choice...
I found old Riken Ohm RM resistors. But... Very expensive.
Quote:I found old Riken Ohm RM resistors. But... Very expensive.
How would Kiwame 2W resistors work for the 1W resistors?
That radiators will conduct worm from transistors. But the case will not cool down while radiators inside. If you want to cool down all stuff in the case there are two options:
1. Make active cooling
2. Pull out radiators from the case
