flashmp3
- Oct 19, 2012
Have totally moved on from the dedicated DAP due to V4A and the ability to use a huge interface.
The Ultrasone Sig DJ are a less dark more detail resolving set that still has a kick ad is very good with fast Techno/House and 808/Dubstep. It is expensive though. The TH600 can slam pretty good and have better detail that the M100 as well.
Do you use an amp??
That really makes a big difference in rec's. If you run straight off a phone with no amp I'd rec the SMS street DJ Pro (wired). I know they are cheap but they are soooo comfy and sound like a better tuned M100 and can give good bass if not over powered.
is the Ultrasone Sig DJ sounding as the Pro 900 with the kind of metallic treble and voice ? I'm gonna have a look at the TH600. Currently i'm just using a Fiio e6 amp to get more volume. I don't really need it but i use it to ensure i can have big bass in whatever song i'm throwing without scaring of earing distortions. Again the HTC M8 audio is really really good.
