- Feb 1, 2011
I'll be getting the A83 soon hopefully.
Awesome H20, thank you so much to you and the others here...I hope all you guys that review get something for your time...whether it be free IEM's, $$$, or just good karma, you deserve it. I will be ordering on Friday and I'm searching the app store right now for the "Equalizer". Once I have them, I will give my feed back about them.
H20 - I definitely agree that EQ'ing down is much better. Based on what everyone has said in the previous posts, my plan of action will be to (obviously) get the H300's from digital852 and get some TS200 comply tips as recommended previously in the Aussie Tour thread for the H300. If the sound isn't up to snuff, I might try the SpinFit tips suggested by xaddictionx...next would be to a go to a better source (DX50) and amp (NX1). Lastly, if that doesn't do it, I'll try different cables. Does this sound like a good plan of attack? Would you change the order of my steps?
Lol about my ears, my ears, MY EARS! My current source is a lowly iPhone4...I will have to DL an EQ app for it (not sure which one to DL though).
Oh ya, almost forgot...H20, have you got your hands on the Fidue A83 yet to compare to the H300's? I'm not changing my mind though, I am getting the H300's!
>edit: Also, let me know how well the tx/ts do fit, I've heard the ts 400 was too large, but only barely. So I assumed the 300 would be the best. I actually asked comply, and because they say they can't "recommend it" for safety reasons (they haven't tested them), they only gave me a hint of what I should use; and they mentioned the 400 as well.
i use tx500. they're fine.
don't hear a difference between t500 and tx500 though.
Tx500 huh? I assumed it would be too large. Do you think tx500 are worth it over t500?
I use tx400 and tx500 as well. I just like it cause it has the filter thing. Didn't notice any sound differences. It being foam is just very different.
Trying to get my hands on the A83 as well.
So both the 400 and 500 fit? What's the difference then?
Seems like you just got the wrong ones and not the one I put on the picture.
