- Aug 20, 2013
Actually, if you want to stretch your budget out a little bit, then you can get the SMSL SH-9 amp used and Sennheiser HD250 Linear II here and still have enough money to repair your Rega Brio 3:
https://www.ebay.co.uk/itm/315265123586
https://www.ebay.co.uk/itm/266752889353
Then, if you can find the time when your significant other is not sleeping, you can also get a Sennheiser HD425 and put some 90mm angled sheepskin ear pads on them (remember to pick the 90mm option with the AE link below):
https://www.ebay.co.uk/itm/144897499885
https://www.aliexpress.com/item/10000339305053.html
Above all else, post your comments on your fixed and new audio setup.
