edit: move info to original post
Superlux HD-330 experiences and discussion
- Thread starter Artsi
- Tags
- superlux-hd-330
Artsi
- Sep 29, 2013
Here is indicative graphs for HD-330 and beyerdynamic DT-990 pro. Measured with bad equipment, so not accurate, but shows biggest differences with bass.
Surprisingly DT-770 and DT-990 pro earpads are totally different sounding. They look like same, but material inside is different. So if one thinks HD-330 have too much bass, put DT-990 pads on.
krist2an
- Dec 5, 2012
I think that one speaker is slightly quieter on mine
Other than that they are a great pair of headphones! Though the stock pads are too small for me, any suggestions which ones to buy?
I think that one speaker is slightly quieter on mineOther than that they are a great pair of headphones! Though the stock pads are too small for me, any suggestions which ones to buy?
Unless you want to EQ, forget 770 velours. I'm pretty confident the (imo nasty) mid suckout is not a fluke in my measurement (yes I did also listen and do other comparo - also Artsis measurement seems to indicate it), also the pads don't feel faulty in any way so..
AKG240 pleathers are much better option. I've been using them for a while and they even start to feel more comfortable than the 770s??
I do still have 990 and 240 velours coming in to try out myself..
GoldenboyJay
- Feb 14, 2014
I need some help and advise comparing this to Superlux 668Bs... I would like to know if this is any better in soundstage and positioning in terms of gaming? I'm in the edge of buying either of the two... There are numerous reviews of the 668Bs but very limited information in terms of gaming for the HD330s.
TheEndGame
- May 20, 2012
668B is better for gaming. It has more detail and less bass.
PS. Listening to Presonus HD7 which I think is Superlux HD681 OEM (but which version?). These sound veeery neutral and airy. Even with little time on head so far, I'm pretty sure I prefer these to HD-330. Even the stock pads are comfy enough.
PS2. Presonus HD7 seems to have some ringing and nastyness around 4-6kHz which is a little bothersome..
Folex
Member of the Trade: PLAudio
- Apr 11, 2009
Is there any american websites outside of ebay that sell these direct ?
HughJanus
- Mar 23, 2014
I just got the HD330 today. 3 hours ago to be specific so I haven't burned them in yet. I don't claim to be super experienced when it comes to audiophile, but these headphones are great for the price. I also got to try out the HD668B and the HD660. They both have alot more clarity than the HD330, but I went with the HD330 since it has a metal band and it's less aggressive sounding than the HD660.
Sound wise, my impression of the HD330 is good. The soundstage is good for cheap cans and it's detailed enough for me. However, these don't give you the feel of the singer/band "being there" even if they are open-back (at least I think they are open-back).
I have no problems with the stock pads and I also have no qualms about the coiled cable. Over-all, a solid 8/10 for me, with price taken into consideration.
TheEndGame
- May 20, 2012
These pads are great http://www.ebay.ph/itm/200951212966. They make the bass better. I also recommend that you remove the foam.
Dozbik
- Nov 19, 2013
Can anyone tell me whether the HD-330 sounds airy? I already have an HD-660 and am very pleased with it, but I'd like to get a cheap circumaural headphone as well. Would you guys recommend this one in this price range?
TheEndGame
- May 20, 2012
Yeah it sounds airy. You do need a decent amp to power it though. And a cold source because it is a bit warm. I recommend you remove the foam over the drivers too to reduce the bass.
Dozbik
- Nov 19, 2013
Sorry, I'm pretty much a dilettante in these things, so I'll ask a couple of amateurish questions if you don't mind. I have Edifier R1600T Plus speakers with an Asus Xonar DG sound card. What do you think, will these suffice?
And secondly, remove the foam over the drivers... hmm... where do I do that? Is there a description anywhere there on the forum?
Dozbik
- Nov 19, 2013
