gorgorsan
- Nov 17, 2012
Hi, Guys. the 2 are not compatible as phones are only 12 Ohms so what do you suggest to sell and what to keep? I've searched for amp recommendation for this current hungry cans but couldn't find any. Also, if you suggest to keep the Canamp instead (will probably be cheaper thus a better option as my budget is around 500 euros) which cans do you recommend the most to go with it? The ones on my short list right now are:
-AKG K701
-AKG Q701
-Ultarsone Pro 900
-Ultrasone Pro 2900
Thank you!
-AKG K701
-AKG Q701
-Ultarsone Pro 900
-Ultrasone Pro 2900
Thank you!
