Elektrospeed
- Jun 12, 2011
OMG! such a simple and fast procedure and it really worked marvels, thanks a lot man!
The perfect fit for me post-stretch (I did manual stretching months ago because I was sick of how slow the "put it on some textbooks" technique worked) is about 2 1/2 inches space between the pads with the extenders fully retracted.
Ill do some manual stretching to see if it works but jerg, didnt you suggest in the mod thread about putting something in the earpads to add more comfort?
I think the clamp is not the main issue i realize for me b/c the m50s fit right on my head fine but that the problem is the pad itself. For some reason it just hurts under my right ear jawbone. I mean both my ears fit perfectly in the pads but it seems the bottom of the right pad is whats touching my jawbone the most. I dont wanna replace the pads cause i heard it makes the SQ worse and i certainly dont want that. Is there something else to do about it. Maybe it is the clamp, i dont know. Please make any suggestions b/c this problem is honestly my only true complaint about the m50s and if it could be solved then i would be very happy. Thank You
P.S: The mod has nothing to do with this since my ears barely touch the drivers and I can faintly sense it. This problem was prominent even before the mod.
Adjust the degree of extensions of the extender belts on either side, see if extending assymmetrically helps.
One thing I do notice is that I need to adjust how the cups/pads sit on around my ear after moving around a bit.
