Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
- Oct 18, 2009
I don't have any personal experience with that... but judging from the connectors that looks like it actually converts speaker level back down to line level so you can plug into another amp. I suppose technically you can connect a headphone to the rca outputs if you rigged up the correct cabling, but I won't even hazard a guess as to how it'll sound. It doesn't even have specs to look up; who knows if its even capable of trasmitting power or if it'll go kablouie when you try to transfer a couple watts through it (recall that an amp input impedance is rather high, so transmitted power would likely be in the mW range)
