sonci
- Apr 3, 2008
It seems obvious for PC audio that when using an external amplifier for speakers or headphones the master volume should be 100%, and you should control volume by the amplifier,
in theory this way should guarantee the best SQ possible,
Well this is true for a lot of cards where the max volume corresponds to the 0dB level, like a lot of professional cards, you set it and forget it,
but a lot of other cards don't show in software the 0 db level, and some of them apply o lot of gain at the max volume,
for example Auzentech Prelude configured at 100% volume often distorts and go in clipping, proof that the 0 dB level is way before the max volume,
For configuring the 0dB level in these cards I use a simple method though not sure if its correct,
I just download some pure tone test files in 1Khz or 500Hz,(http://www.ronelmm.com/tones/) play them through Foobar- Asio (Audio Creation Mode) with the volume at 50%(windows volume, foobar`s is always 100%), then measure the outputs of the cards with a RMS multimeter (AC with V scale) (+ and - of the RCA plug)
normally at 0dB level volume the card should output 1V rms, so I just raise the volume until I measure 1V with the multimeter, for the Prelude the 0dB level is around the 82% volume, so this should be the optimal level for bit perfect output,
What do you think? What are your volume settings for the other cards?
