- Oct 14, 2013
Have you tried the Z5 with any other headphones at the moment? We're all anxious to hear about the sound quality compared to other phones you've used?
People often make the mistake that 4 is better than 3. However the BT 4.0 and 4.1 standards were specifically developed for wearable devices / internet of things, and wouldn't make any difference to the sound compared to BT 3.0.
If you are after the best available sound quality over Bluetooth you're in luck because the Z5 has LDAC - the highest spec BT codec available. If I were you I would strongly consider the MDR-1ABT - Sony's flagship BT cans and the only headphones with LDAC support in existence today. They also have AptX and SBC, of course, so you can use them with any BT device.
Well said, and is exactly what it is
I wasnt clear enough in my last post. I got the z5 compact model, not the z5. I have been listening to hq streaming through spotify with a pair of sony mdr-1a and sennheiser hd 598 headphones for a couple of hours. The only phone that i can compare the z5 with is an iphone 5 and the sound is so much bigger and more spacious in the z5 in all aspects even with clearaudio+ turned off. When its turned on it rules, the voices gets centered with all instruments well positioned in space. I think i get enough volume in my ears, if it would produce more, i would probably become deaf in the near future.
The camera is very very good with a very very good autofocus. I do find the fingerprint sensor a little bit to sensitive for my big fingers, resulting in alot of opening failures. I bought sonys orignal case and it makes the phone look more expensive. One problem i have is that the protective lid easily gets in the way when im trying to put my finger on the sensor button. The battery is a clear winner and it last for two days, as they promise. The reason i choosed the compact and not the z5 is the size of it, i want it to fit in my palm, and that it does. Even my doughter is impressed by the phone and she takes alot of photos and listens to alot of music, she own an iphone 6, by the way.
I want BT 4.1 because it seems to demand less power and by that the battery will last much longer. Sounds like music to my ears
I think this is just the same sound quality as the Z3. There is nothing changed within it Audio circuitry lay out, design, components. However, it does have LDAC for bluetooth
