djricekcn
- Dec 2, 2014
what happens if the battery is removed or completely dies int he USA version (or JP)...can it still run just with AC?
;l,.which means no matter what DAP you''re using, you're going to get the PHA-3's DAC quality for balanced audio.
Warning about the PHA-3AC: I got my balanced cable, and got an audible hum from the headphones' left channel when switching to line -out, even with nothing connected , not even the power supply.
Since I thought this was very weird I asked on a more technical oriented message board and someone found the answer in the PHA3-AC "help guide" ( http://helpguide.sony.net/mdr/pha-3/v1/en3/index.html
search for "battery" in the built in search function): The PHA-3AC has a battery to "support the power supply" , so going for the AC version to avoid battery wear is useless, since it has a much smaller battery (it weighs 70 grams less). Most likely the amp won't work once the battery fails.
The phrasing "support the power supply" and the way my charging light comes on also supports my idea that the AC charger cannot supply enough power on its own: After playing high resolution files through balanced outputs for a while the charging light comes on much longer than when using sensitive headphones with standard cd quality files. I would not be surprised if it would simply shut down after pushing it hard for a while, since the battery is probably too small to "support the power supply" for a prolonged time. I am not going to try it, it's in the box and going back to the store, but like I previously said: The maximum rated power consumption is almost twice what a regular USB phone charger (which is supplied) can deliver.
A USB computer connection will also give you balanced. At this time, a computer connection is also the only way of getting pure DSD to the PHA-3.
Computer is not the only way. Thru Android is possible as well using USAPP.
Oooh! I had no idea about this app...will give it a try! Thank you very much for posting about it
I never had this issue, but I use foobar2000 and upsample everything to DSD256 on-the-fly when playing.
It's strange they don't list DSD256 capability (only DSD64 and DSD128) but PHA-3 can decode it. I've also tried DSD512, it's not supported.
Took me quite a while to configure the Foobar as I've missed a few step. Now running nicely. Thanks.
How do you upsample everything to DSD256?
