animalsrush
- Aug 15, 2005
Well, iam sorry to say this and i know that people may not like what i saybut we can just agree to disagree , no hard feelings
between the onkyo and stock app there is a very significant change in sound, the onkyo is very flat.
with the gone mad i have compared some songs for more than an hour.
and it is not near flat, in fact it is the same stock player sound (now people will not like this)
But i compared very well alot of songs going 3 seconda at a time.
i had the hardware buttons control the stock, and i had the gonemad app on screen with the same song.
i press play on touch screen and hear 3 seconds, then pause gonemad while same time pressing play on hardware button with no latency or lag at all, so i hear the 3 seconds twice directly after each other
I hear the exact same 3 seconds not a single tiny change in frequencies.
so i say its either uses android libs (onkyo) or sony libs (stock or gonemad),
thats my humble opinion, i will stick with the sony since i like the UI better and there are fast forward and rewind.
if you like the sony stock app as a gui in anyway, then try to compare SQ again.
if you prefer gonemad gui, then i guess your good to go. (As iam pretty sure they are the same )
on other hand, i have been comparing using my new just received ANGIE and WoW!!!
+1 .. Onkyo sounded worse than stock and Gone mad made no difference to my gear. So really didn't see the point of switching from stock sony player. I am glad someone else had same experience as me ( I didn't chime in earlier as i didn't want a flare up as few people swear by those apps)
