harmonix
- Jun 13, 2009
Yes, I've tried Sandisk and Lexar. Sandisk actually uses flash memory very similar to Toshiba, they jointly developed a lot of their flash technology, but Sandisk does not build in Japan. Sandisk sounds nearly as good as Toshiba though, smaller capacity still sounds better to me with Sandisk. Lexar is owned by Micron, a large USA company that develops flash memory, they also have some good quality cards in smaller capacities. Samsung is my least favorite. These 4 companies all make their own flash memory, every other company buys from these guys and just puts their own name on it. Even Sony, its probably another reason why these premium sound sd cards are so expensive, because Sony would most likely have contracted the work out to either Toshiba, Sandisk, Micron or Samsung for the actual custom production of the cards, Sony just designed it most likely.
Thanks TRANCE. First Head Fi'er to identify Sony's OEM for this card gets a prize!!
Seems lower capacity cards yield better results. How about lower speed cards?
Hmmmm... If I was a real nut job at Sony - I would have designed the ZX2 card slot chamber with a a EMI/RFI shield cage around it - but what to do with the contact pins....
