audiophile-ish
- Sep 11, 2011
Just used the Amex offer and the student discount offer from Sony to snag a pair for $118.
I only know how to access hq bt mode (3 blue blinks by holding pow and vol+). How do I get the bt to normal and stable mode?
That's too bad, they do get less boomy and the mids/highs come out after 100-150hrs but your call. This difference between out of the box and burned-in is substantial
Hold volume up for aptx mode, don't press anything for normal mode, and hold volume down for stable mode at the same time as you hit the the power button to turn on the unit.
You can check what mode it is in while the unit is powered on. Hit the power button - And while still pressing it - tap the volume up button then release both. The light will blink 1-3 times. Of course, don't hold the power button down too long or it will shut down.
I was under the impression that it stays in its mode, you shouldn't have to set it on each power up.
So, which albums do you guys enjoy with your 950 that sounds fantastic?
I'm currently enjoying some Sinatra and Bassie.
Also, this album sounds great as is but it's one I can boost the bass and still be able to hear the highs and mids very well. Nigel Stanford's - Solar Echoes
