lee730
- Jan 9, 2011
You aren't alone. *zips up JVC suit*
You bought them again? Or did you ever sell yours? I'm loving the FX700s, they grow on me the more I use them.
hello just need your advice guys..
i've narrowed my choice between the ex1000 and fx700s..
when it comes to durability, are the sonys more durable? since the jvcs are made of wood?
which would be the better rounder of the two?
these are my genres
r&b,hiphop/country > metal/rock > classical/pop
if ever, would the ex1000s satisfy me on its sub-bass and mid-bass? i'm not really a basshead but i do like the bass from the 535s and especially the coppers and kinda enough for me.. do they have more quantity than the 535s? or the same as coppers?
i like the mid bass especially for country songs (eagles, taylor swift, MLTR) ... how would you compare the mid-bass pf the sonys to the senn ie8s (minimum setting)
really looking forward to your help guys i'm about to pull the trigger on these just need more justification to it
thanks
The IE8's are much more awash with mid-bass, whereas the EX1000's present the low end much cleaner. Two different beasts in bass entirely.
The FX700s would be better all rounders than the EX1000s. The EX1000s are more tailored to romantic and soothing music and not that great for rock IMO. They are ok but not great at it. The JVCs are very durable and I wouldn't worry about it but they are very nice looking so of course you would want to try take care of them. I tend to be lazy though and put them in my pocket without the case.
oh thanks but a little more elaboration would help
so you think there is still some warmth on the sonys for country songs?
how do they differ in terms of quantity/quality with the coppers? i find the bass of the coppers best and neutral and extends deep if needed..
a little more and i'm done
thanks
alright thanks i'm gonna have to think about it
i'm really bugged with the sonys like my heart says get them ...
i'm not really into the warm side i just need some of it like a less more of the ie8s (minimum setting)
but uhmm i'll just sell them if ever i don't like it but ii hope i would be very happy and satisfied with it..
If I listened to country music I'd probably lean towards the JVC's.
The Sony's are pretty neutral.
It's not warm sounding, but personally I'd consider Shure SRH-940 as well, due to the way it does vocals and acoustic guitar and so on.
The current FX700's I own were purchased second hand, and are over a year old, and they are in absolute perfect condition. According to the original seller, they've been put to HEAVY use in the time s/he owned them. I can't personally offer much feedback with regards to the EX1000's build, since I didn't own mine nearly long enough (~2 months, until I opted for the less expensive alternative, the EX600). However, aside from the letters fading and potential paint chipping, I'd say the overall build quality of the EX1000 is NOT much of an issue. Nevertheless, I'd rather someone here who's owned them long enough provide their insight, as I'd hate to mislead anyone by even the slightest.
these are my genres
Quite honestly, in my honest opinion, either one is equally as competent as an all rounder. I've heard a very wide assortment of genres and tracks with either one, and have never felt one lacking for a specific genre. In that regard, the FX700's surprised me more or less, considering how prominent both their highs and lows are. All the while, they offer a very naturally pleasing sound.
If you're leaning towards bass similar to that of the 535's, you may find the FX700's bass a tad too overwhelming. However, I assure you, as monstrous as the FX700's bass may be, it's all the while very well controlled in my opinion, and while the FX700 does boast more midbass as compared to the EX1000, either one is completely free from any appreciable midrange bleed. In fact, I was initially under the misconception that the FX700's bass was overshadowing the mids, but with the right tips, you'd be quite surprised to find just how natural the mids sound. While I no longer have the Coppers on hand, I'd say the EX1000 gains the edge over both the Coppers and SE535, in that I personally find the lows to offer a much better blend of quality and quantity.
The IE8's, which I currently have on hand, have much heavier midbass presence than does the EX1000 (even at the lowest setting), and not to it's advantage either in my opinion. I'm not a fan of emphasized midbass, as it can begin to sound bloated and muddy at times, especially when it begins to intrude on the midrange. As mentioned however, either one of the two (EX1000 & FX700) are free from said midbass hump.
thanks
Did you ever listen to the JVC's Kiteki? They are amazingly good sounding. Then again its not everyone's cups of tea .
Okay so it seems like the diaphragm material in the MDR-7510 is Polyethylene Terephthalate,I can only guess that's what's used in the EX700, EX600 and EX800ST.
The MDR-7520 is Liquid Crystal Polymer.
Edit: scroll to the last page http://ws.sel.sony.com/PIPWebServices/RetrievePublicAsset/StepID/SEL-asset-248342/original/mdr7500_headphoneseriesbrochure_a1149b.pdf
stuff here too: www.sony.com/proaudio
