wakibaki
- May 26, 2011
You'll get better results if running the buffers in high bias WB mode(with a jumper instead of resistor).
Otherwise,I'm pretty sure that offset will be lower that 1 mV even without the servo(I've got same topology amp,just with BUF634).
The option to run in NB is something I added at the suggestion of Avro_Arrow. Evidently another member felt they had better results that way. Obviously the link can be made with a 0R resistor.
sek@ reports 50mV offset from his build of THE WIRE.
The purpose of the servo is not only to control any internally generated offsets, but (in conjunction with the relay) to ensure that no offsets in the source are passed on (amplified) to the phones.
Thanks for the input though, let us know if anything else occurs to you...
w
I bookmarked your blog.
