Small impact on HD800, is it a problem?
May 10, 2022 at 12:56 PM Thread Starter Post #1 of 8
Haruhiiste
Hello everyone!
I just bought a second hand (ofc) hd800, but I found a small impact on it on the left side that you can see on this photo :
Do you think it might cause distortion on the sound or it's too minor to be audible?
Thanks in advance!
May 10, 2022 at 6:59 PM Post #2 of 8
Too minor to be audible
May 10, 2022 at 7:20 PM Post #3 of 8
No big deal. You might even be able to press it back out if you put gentle pressure on the screen from the inside pressing outwards.
May 10, 2022 at 7:57 PM Post #4 of 8
That will be a cosmetic issue only. Daijobu.
May 11, 2022 at 3:48 PM Post #7 of 8
As mentioned… no issues, and you might be able to level it out by pushing the dimple out on the inside👍
