plug it into the same power strip that you use to power your other equipment. Not sure whether it is to be plugged into a socket closest to the strip's power cable or the one furthest.
or
plug it into a socket using the same power line that has an appliance that could generate electrical noise that "bleeds" back into the line, an example of an appliance being a refrigerator.
Hope this helps. I cannot vouch for whether it works cos I really dunno. If you don't mind.
