muscular
- Jul 3, 2009
I've moved on to the IE800s.
But I still sometimes crave for the IE8s which I haven't let go yet, I had them with the Twag v2 and they sounded very relaxing, with details laid back.
In any case, if you were to consider the SE846s, you could jolly well place the 1+2, TG334, k3003, IE800s within your considerations.
But those are really a notch higher in terms of pricing as well.
In fact with your needs, I wouldn't recommend the IE800s although I very much liked them, they're really bass heavy and has details straight up in the face, may be fatiguing for some.
That said, I've always found bright IEMs to be even more fatiguing, brain takes too much processing to identify all the details.
Oh, because in the advertisement I saw $, so assumed it was an an inflated price for some reason. But yes, in all honesty, the color and reviews that the sound is very fun and different for a very wide array of music from classical to pop was very good. But thats why I went with amazon, if they are not satisfactory in anyway, back in the box and returned for another pair. But I do appreciate all your advice. I did notice you own the IE8s, if these are not to my satisfaction, I believe they will be the next pair I go with, since Sennheisers have been the only quality audio devices I have owned.
