SENNHEISER MOMENTUM 3 vs SHURE AONIC 50
I consider myself an average person with needs for sound, but I’m a professional musician (clarinetist), so I feel that I CAN be critical of sound sometimes. I don’t listen to music often, but it’s typically not pop music, it's more classical, chamber, or jazz (various styles and eras of jazz). I prefer clarity (I HATE muddy sounds) and am not terribly sensitive to sibilance since my playing naturally LIVES in that high frequency world. And if/when I have free time, I’m watching movies (I own about 500 dvds/blurays!) or playing video games (first person shooters, single or multiplayer… or anything epicly awesome like The Witcher 3…. Seriously… buy and play Witcher 3 if you haven’t yet… it’s story, gameplay, AND it’s music and sound in general is AMAZING!!!!)
TL;DR 1 – I prefer and will be keeping the
Momentum 3 for it’s more “fun” sound (I use my headphones for entertainment), wider soundstage (to me feels more ‘immersive’ when watching movies and playing games), and better implementation of multi-point pairing (from my limited testing). Also, keep in mind that the Momentum 3 has an equalizer with presets you can save (a very wierd way of implementing one, but it's there) that is saved to the HEADPHONES. This means I can tune the headphones on my phone while listening to it, and then connect it to a totally different device (not my phone at all), and get that same custom equalizer applied to the sound. The A50 has an equalizer that only changes the sound while you're listening to music through the app on your phone.
TL;DR 2 – Both are really good headphones, and if you’re interested in more critical listening out of the box or are afraid of battery life/want to listen with headphones unpowered, get the Aonic 50. I was looking to replicate a "movie theater" experience at home with headphones. And the tuning and soundstage of the Sennheiser seems better for that.
I’ll put my details below, it was a fun little test.
NOTE: I only spent maybe two hours going back and forth with A/B tests. But it was enough for me to make my determination. As in, play one minute of a song or section of a movie, or other thing I would normally listen to, rewind, and put the other headphones on. I tested them both in wired mode using the same cable (both use a 2.5mm input) so I just unplugged one set and plugged in the other to minimize variables. I also tested the ANC without music against varied normal noises in my apartment to see how well they worked JUST as a concept, without any music or videos being piped in. Lastly, I tested them in Bluetooth mode to see how quickly they found and how securely they stayed connected to devices, and test their multipoint pairing for scenarios I would normally use.
Pros and Cons (mostly as compared to each other), in various scenarios
COMFORT – TIE
They both have something the other doesn’t have. But I think both are suitable for long-term wearing.
M3 – Comfortable. The headband and clamping force might be a LITTLE much for some. The headphone band takes some fiddling to get in the right spot to annoy a hot spot. But the earpads are nice and plush, and DEEP. My ears (I think they’re average, don’t stick out too much, aren’t flat against my head) don’t seem to touch or feel the speakers.
A50 – Comfortable. The headband and earpads are very comfortable, but my ears touched and stayed touching the cloth over the speaker. Similar to the Sony WH1000xm3. I doubt this would be an issue for many, but for me, it was a little annoying. Although I’m sure I would forget about it or adjust to it after a while.
MUSIC IN PURE PASSIVE MODE (power off on both headphones) – Winner, A50.
It wasn’t even close. The M3 NEEDS power to sound good. It’s not HORRIBLE without power (Sony WH1000xm3, I'm looking at you...), but the A50 is MILES ahead. The A50 sounds really good without power. The M3 is lacking without it. But it DOES work well enough that you can use it in an emergency until you can charge it again.
MUSIC WHILE POWERED, NO ANC – Winner, MOMENTUM 3.
Nothing really to add. Just that I prefer the “fun” sound, and noticeable wider soundstage of the Momentum. I would say, A50 = analytical, M3 = entertaining and still clear. Both good, but my sonic priorities are soundstage and fun for movies/games. M3 serves that better. If my priorities were listening to music, I’d probably go with A50.
ANC PERFORMANCE – Winner, MOMENTUM 3.
I intend to use them at home. I have no public transportation need to test them, so I tested them against my computer fans if the fans were ramped up, my central air in my apartment, and the kitchen vent if I was cooking, as well as with silence in the apartment.
NO MUSIC
M3 – It works pretty darn well. It’s not as good as Bose or Sony. But it’s good enough for me. At MAX it blocked everything very well. And there was little to no noticeable “hiss” when you turn it on without music.
A50 – Doesn’t work well. It works, but just not well. Even at MAX, I could still hear my fans on the PC next to me. The M3 made them disappear. Also, you WILL hear that “hiss” when you turn it on (to max).
PLAYING MUSIC
M3 - Very little difference in sound between powered, and turning on the ANC. Sounds fine.
A50 – Noticeable difference in sounds. Couldn’t put my fingers on it, but I preferred the subtle change it made WITH ANC. So if I were to keep these, I’d just leave it on the “normal” ANC setting (to avoid hiss) and always leave ANC on.
BLUETOOTH PERFORMANCE – Winner, MOMENTUM 3 (for ME)
Yup. A50 has more codecs. But more importantly, what codecs to YOU need? THAT’S what’s important! As much as I loved the convenience of the way the PX7 was setup, it didn’t have a low latency codec and for MY use case, I needed low latency. So for me, I need AAC for my iOS devices, and aptx-LL. Anything past that are just “bonus” codecs.
MOMENTUM 3 Performance
It finds my devices just fine. The aptx-LL works well. The big reason it wins is the application of multipoint pairing. Here’s what happens. I connect to my TV transmitter, and to my ipad. It plays the audio from my TV. I open my ipad, and it stops playing audio from the TV transmitter for the “click” of the ipad, and then resumes the TV when I do nothing else. I play a song on my ipad, and it changes to the ipad. Until I stop the song. Then it changes back. Same situation with my PC audio and TV transmitter. I play a youtube on my computer, it switches to the computer. Youtube video ends, it goes back to TV.
AONIC 50 Performance
It finds my devices just fine. The aptx-LL works well. But the multipoint pairing doesn’t work well (or at least intuitively enough for a dunce like me since I couldn’t figure out how to make it work). I connect to my TV transmitter and to my ipad. It plays audio from my TV. I open my ipad, nothing happens. TV continues playing. I play a song on my ipad, and all of a sudden there’s loud crackling. I leave the audio playing hoping it’ll recognize, but it doesn’t switch. I pause, and EVENTUALLY it goes back to TV. On my PC audio, it never switches from the TV. I can play a youtube on my PC and it doesn’t switch at all. Even though it clearly shows up as connected. FWIW, if I was ONLY connected to the PC, sound plays just fine. So it’s not a codec or Bluetooth issue. Just a “how it handles multipoint” issue.
BATTERY LIFE
Obviously the A50 is rated higher. FWIW, I woke up yesterday at 0900, put on my Momentum 3s with ANC, and left them powered on and on my head caused I was watching movies all day. Hey! It was my day off! Don’t judge! When I went to bed at midnight, the app said they were at about 10% (the app is not precise, it approximates). Since I use these at home, I could have easily done a quick charge halfway through, or plugged them into a battery bank while on my head for one movie to fully charge them halfway through the day. They’ll be just fine and I won’t need much more.
If you read everything, I both congratulate you for dealing with my long-windedness, and also pity you for having to read my disjointed, haphazardly organized thoughts. Maybe this will help someone down the road.
Thanks all! It was quite a Journey figuring out which company was going to get my stimulus money, but Sennheiser, you have won this round. But years down the road as the battery life lowers to a point where it becomes annoying? Well… we’ll have to see….
Alexi
