I know that where i can get a 3.5 mm adapter for the one end of the cable but where can i purchase those two prong plugs that get inserted into the TF 10 IEMs themselves......also did you buy a spool of jena wire .....25 feet goes for about $125 and if so did you use the whole spool.
I found this site for wire that i have not heard mentioned on here before .....they have braided silver wire...if you have heard of it how does it stack up to the jena. This is the Website
you do not wanna use a solid silver wire in a headphone cable. I believe the only place where a solid silver cable belongs is in the ground of a lod cable to be honest with you. For a headphone cable you want everything to be stranded and for tf10's your going to want to use copper which imo gives the cans the best balance possible
I thought the null was a solid silver braid but i will take your word for it and go copper with jena. I get my TF 10 at the end of the month they are on back order from amazon for 310 no tax free shiping ,Qusp made me a really good LOD and i have a P-51 mustang ....i just have to get the right comply tips and make or buy a IEM Cable. I am new to this and want to make the right decision before spending the money.
hockeyb, jena cable a lot better than null audio cable? i'm balancing between SQ and portability but since u mentioned jena's not really easy to roll up.
Jena is significantly better then the null cable and also I don't like how the null cable tends to hold its bends and feels cheap in my hands. It is easy to roll just it won't be able to fold as small as a thinner cable would if needed I can post up some pictures displaying it
I think i can imagine what u trying to imply. Those Jena are multiple strain cables, right? With 3 cables on each channel, definitely flashy and suit the banana shaped IEM well haha.
Btw, if it's really 3 strain of cable each channel, ever think of sleeving it?
there is 4 wires in the cable a signal and ground on each channel hence why there is 2 prongs on the connector I would not consider sleeving because all that would do is cover up my gorgeous cable and make it less flexible
Ouch, forget it's separate ground signal. I still think whether i should scarifies my stock cable for its connector.. Probably will end up trying ES2 or Null cable.
