Its been great! Listening to it through the ER4XR and I really love how holographic the sound is, plus everything sounds so natural and linear so far..
Nothing is overly emphazised with the Alien+.
U know what? It got me with just the very holographic presentation hahaha!
Very sorry for just replying and I do appreciate it very much for helping me.
I am exploring the line-out now and thinking what portable amp would suit being paired with the Alien+.
*I originally thought that getting the Alien+ was to avoid buying an amp.. Oh well, my poor wallet hahaha!
Hi guys, couple of questions over this DAP:
1) why is unavailable (as per new) everywhere? is it discontinued already or what?
2) does is still not provide DSD playing, correct?
recently bought one, however my Windows doesn't recognize the device while in DAC mode (I have the latest firmware from 2017). I'm enabling this feature by clicking on power ON + the middle button, "USB AUDIO" sign shows up. I connect the player via USB and nothing happens ? Is there any additional driver required ? I cannot find any other option besides usual inside built speakers to choose from. ThX for help.
Any suggestions for pairing Shozy with a particular amp , e.g. for ER4 or any other IEM, or would it be just better to move on with a more refined, meaning more expensive, DAP?
Fiio A1. I like it a lot, it doesn't interfere so much with the sound signature of the Alien, but helps me reach volumes I appreciate more than natively without. Pressing the EQ Button gives you this pattern; EQ Normal (ie default, really sounds like it doesn't add or change anything the Alien does, just allows for greater volume)>EQ Mid Bass boost>EQ Low Bass Boost>Bass Reduced.
So not an 'EQ' exactly but a bass boosting (and even reducing) button that gives different kind of boosts. I find it useful, depends on your taste in music I guess. I listen to older stuff that benefits from some bass boosting as well as newer underground rap stuff that can have overwhelming bass and so I quite like being able to pull that back at the touch of a button.
My only complaint is that with each press of the EQ button there is a slight silence gap, it's not fluid (not how it is with the AP100 and it's dedicated EQ button, when you press that it cycles through different EQ presets uninterrupted).
Still... the A1 is pretty cheap, worthwhile having I reckon. I hope it's successor manages to get rid of the silence gaps/pauses between cycling the EQ button.
