Partlys4int
- Jul 12, 2015
http://www.cypeurope.com/store/store/app/browse/category/7200/Audio/Audio-Converters
Thanks
Yes, it's the AU-D4 you'll need, if you proceed to buy it. No problem =)
Thanks
Thank you! Valuable help
Nice review. I am actually interested in purchasing these headphones, I will be mainly using them for Gaming would anyone recommend them for gaming or are they poor when it comes to it. I would be using them for FPS games so the large sound stage should be good. Will it be easy to locate the enemy or should I look elsewhere? Wireless is my only option right now.
Hi Dexterr
The author of this RS185 review really knows his stuff. He mentioned that if need be, to get the cheapest sound card since you only need it for the plug.
His reply is somewhere in this RS185 review.
185s are down to $219.99 on Amazon... a no-brainer!
since they're open is it wrong to add surrond sound, will it ruin it?
So I will use virtual surround sound then from an amp. should I?
