maniac2003
- Jun 20, 2009
No LDAC and only 17 hours of battery life? Sticking with my Sony for now.
Thankfully, it looks like they retained the steel. Now, if they only updated the app to support a 7-band EQ instead of that silly dot.Looks great. Other than the exposed wires, which I’m surprised aren’t integrated into the design considering how modern it looks otherwise. They replaced the steel with aluminum and it looks like they added venting for the bass and maybe a larger soundstage.
Listened to the Momentum 3 today. They seem to have more or less the same sound signature, but they definitely sound thinner, there's just less body to the sound. Don't get me wrong it sounded good, just slightly more like a nice suit. But you don't wear a suit to a metal party, if you get what i'm saying. That's why i'm slightly disappointed.
My question is, i would be interested in knowing wether burn-in has any effect on the Momentum 3. Anyone own these yet?
I posted here because people are familiar with the Momentum 2 wireless, which is what i'll be comparing them with.
No, i could try that.Did you try tweaking the sound with the app? That's one thing that the 3 has that is lacking on the 2.
This is what I have. Works for me.
https://www.amazon.com/dp/B00KAU6LMQ/ref=twister_B01D4ZJZTO?_encoding=UTF8&th=1
"Thank you for contacting Sennheiser Technical Support. Yes, the Momentum 2/ HD1 headphones support the AAC cdec natively."
I cannot confirm off the top of my head if the Momentum 2/HD-1 over ear wireless supports AAC off the top of my head (the wireless In Ear definitely does), I'll look into it, ask the engineers. Side note, apparently the current generation of MacBooks actually does support Apt-X output over bluetooth, so if you have that Apple model you should still get very high quality wireless.
Update: I've been trying for a while to force these headphones to use AAC, but they won't receive AAC on Mac no matter the config or iPhone 7. Apple Bluetooth Verification tool says that the Momentum supports AAC so I'd really appreciate if Sennheiser can run it by a few engineers to enable it. It's an issue on the headphone side, not Apple.
Compared aptX on my Mac to my iPhone, which should use AAC if it supports it, and the iPhone is definitely using SBC.
Sennheiser doesn't even list AAC as a codec for the M2. Let's fix this as it could support it with some help on Sennheiser's end.
Does the momentum wireless sound decent connected wirelessly to an iPhone seeing as it lacks aptx and the momentum doesn't support aac? Would it be worth getting a phone with aptx or is the difference not noticeable?
Most reviews you see online from consumer-oriented websites are done with Momentum Wireless over SBC. It sounds good but nowhere as good as the wired version. It's still one of the best options around if you absolutely need wireless for some reason.
Not sure what happened but it sounds like wireless on iPhone is greatly improved -- maybe AAC support started working, or Apple improved SBC via an iOS update. Maybe even preferable to wired and aptX as it sounds livelier than the former and more natural than the latter.
I have the wireless version (bought a couple years ago from Amazon) and they have the black logo.Hello. I have just bought an used Sennheiser m2 aebt wireless and I am doubting about if they are fake. Does it exist a counterfeit of these headphones??
The thing that made me doubt is the logo in the lateral, it is Black instead of holographic like in wired version.
I also own a wired m2, and the rest of the headphone looks good, the sq looks ok with aptx codec and the pads (used) have the same touch sensation.
Have your me wireless Black or holographic logo?
I paid about 60€ for them in a shop (cex) without box or case, but I have 14 days to return them
Thank you very much. It was the confirmation I needed.
When I searched in Google images, it looks chrome/holographic, but I saw that the ones on sale on eBay, have the black logo.
The wired version seems to sound better connected to my lg v30. Now, when a pair of 1000xm3 I bought for 100€ arrives, I have to compare them with the m2w, qc35, qc35 ii and 1000x v1, and select which one to keep
