Bought mine on the Amazon sale and they checked out as authentic.
Sennheiser IE80's Impressions Thread
- Thread starter Craigerz
Sounding mighty impressive now. Bass has tamed down alot, thank fudge.As it stands would rate these as a tighter IE60. Rate them a touch higher than my GR07 based on my sound preference. I like a bit of bass boost, GR07 had an anaemic sound on alot of the edm tracks I listened to but were spectacular on anything vocal focussed.
Vsd3s sounds very similar to IE80 but bass feels a little less controlled to me and has the typical Vsonic sibilance. I would rate VSD3S as the best budget IEM under $50.
Compared to IE60. IE60 has a more prominent mid, less bass. Treble is about even. A very intimate sounding IEM,voices sound so close which I prefer over massive soundstage for rock, rock on an IE60 is a highlight. My IE60 have improved an incredible amount over time and I expect the same from the IE80.
DivineCurrent
I'm thinking of getting these to pair with my Klipsch X10. Does anyone here have the Klipsch X10 in order to compare them to the Ie80? From what ive heard, the IE80 might have slightly elevated treble in relation to the X10. Would that be a correct assumption?
OwOOwO
- Aug 29, 2015
I used to hate my IE80 with a passion - they sound pale and flavourless from a ZX1, one dimensional and lack of detail from a PHA3.
Today I plugged it into my laptop, hardly qualifies as an "audiophile gear" and boom! I was totally blown away by the result. It sounded balanced and accurate; best of all it had the proper 3-D laying of music which I only get from a full size headphone.
Ok, it still doesn't have the level of detail which current gen IEM enjoys but it's not too far behind either. It has become my default audio gear at home now XD
Taggerung
- Dec 14, 2015
The IE80s have been at it's lowest price ever for a week now. Anyone bought a 2nd pair because of this, or as insurance in case of the unthinkable?
skyline385
- Nov 22, 2012
Almost 20 hours burned in (whether that actually matters or not, the debate will never end) and i just received my Spiral dots (M size; i use M tips and these fit nicely and comfortably) today. First thing i would say is that people who buy IE80 exclusively for their bass should probably avoid this. The bass definitely feels weaker when compared to the included Foam tips and slightly weak when compared to the regular tips. The sub bass is there and highs feel more pronounced and clearer (compared to the double flange tips i was using before). Also i am not noticing much of a change in the soundstage, again when compared to the double flange tips. To conclude, i would say that the IE80 feels more balanced with the Spiral dots.
EDIT: I would also like to add that i was testing them with my E17K/O2 combo and i must say that the instrument separation of the O2 combined with the soundstage of the IE80 makes for an amazing combination. The difference was definitely noticeable to me.
raybone0566
Ie80 has bass adjustment setting on each ear piece. With the right tip selection & seal, the bass will go very deep. They hit hardAlmost 20 hours burned in (whether that actually matters or not, the debate will never end) and i just received my Spiral dots (M size; i use M tips and these fit nicely and comfortably) today. First thing i would say is that people who buy IE80 exclusively for their bass should probably avoid this. The bass definitely feels weaker when compared to the included Foam tips and slightly weak when compared to the regular tips. The sub bass is there and highs feel more pronounced and clearer (compared to the double flange tips i was using before). Also i am not noticing much of a change in the soundstage, again when compared to the double flange tips. To conclude, i would say that the IE80 feels more balanced with the Spiral dots.
yangian
- Sep 22, 2014
The best gear I found for the IE80 is Nexus 7 with Neutron amplified by NX1. Amazing sound!
castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
the best gear for me to use with the IE80 is anything that doesn't hiss ^_^.
I bought a cheap Panasonic iem just to try out the tips. Cut the stem by 3mm and added a decored medium comply foam tip and getting a good comfortable seal and now am extremely impressed with the sound, or should I say even more impressed now.
OwOOwO
- Aug 29, 2015
So...after a YEAR of ownership, I have finally figured out why my IE80 sounded so bad - drum roll please:
I have accidentally set one side to MAX bass and the other side to MIN bass XD
Now everything is good and I am a happy bunny.
castleofargh
- Jul 2, 2011
welcome to IE80 anonymous. you can tell us everything.
I believe I have spent my first 2 months of owning the IE80 like that. influenced by symmetry logic instead of looking at the small engravings ^_^
Oh, boy... It must have taken a lot of courage, to bring this to the light.
pokenguyen
- Jun 26, 2013
Amazon is on sale at 200E, is it worth anymore or any other alternative? I currently own HD650 and like its sound very much.
Thank you
Thank you
EagleWings
Thank you
If mids are not a real deal in your music preference, you can jump straight in and get the IE80.
If you want good resolution in the mids and don't mind a barrel design that sticks out your ears when you wear them, you may want to check out the JVC FX850.
Total: 6 (members: 0, guests: 6)
