Audiocrack
WARNING: BAD TRADER
Also known as HeadphoneViking & VictorHalgaard
- Apr 23, 2012
Alright just did Gateways from Abrahadabra, I guess around 3:20 is when it gets busiest. All the kick drums, guitars, high hats are separated easily. Honestly, the song is a little slow for the HD800 and it begs for more tbh. Children of Bodom gets picked apart cleanly but the imagining on the masters is pretty soft, the tracks are not mastered very well. This is all via youtube which sounds god awful on my rig.
I'd recommend Limpbizkit, 'Take a look around' where the cymbal crashes want to collapse into each other. They should be rendered clean and not as a wall of noise. Also Green Days, 'American Idiot' is very clean and images/separates everything beautifully at all times. You should be able to pick out every note on each instrument on the track. The HD800 handles both beautifully and cleanly picking the pieces apart and not blobbing things up. Use wave files or flac if you can.
The first part of that mostly makes me wonder if we are either not talking about the same thing, or you somehow have a different/somehow worse version of the tracks? I listening to the actual CDs through a Thule cd player, and the drums in most of Dimmu Borgir's track tend to speed up to a point where the T1 seems to mostly just give up on making it actual kicks, so much as just sort of bumps in the sound - the HD800 while being a liiitle bit light seems to have pretty much no problem at all... But apart from that...
