Embed
- Oct 12, 2013
Hi there,
First post here, really like the site
So I've got a problem with my 25's. The sound is dropping out of each side and I have determined that its due to the cable.
The end of the cable that plugs into the headphones (red and black) with the two spike connectors is somehow loose and is failing to keep a connection.
If I push the protruding part of the connection I can get the signal back but I have to keep it held otherwise it just drops again.
Now is this an issue people have seen before? If so, will a new cable help the issue? I'm in 2 minds if it will or not because there is nothing physically wrong with the cable I have right now and the spiked ends are immaculate.
Can you suggest resolutions or anything that might help?
Many thanks in advance
