Sennheiser HD 598 Impressions Thread
Arsis
- Apr 2, 2013
bugeyed
- Aug 16, 2013
$15 each is a rip off! This type connector needs to be made of high quality plastic, so it doesn't melt when soldering too. These are likely a very cheap Chinese product of questionable materials. Even if it was teflon, $15 is way too much! It'd be cheaper to buy one of the ready made cables & remove the connectors if you want to use your own wire.
kev
ben_r_
kev
Sure. Well either way I just thought Id post so that others at least know they are out there. They will drop in price soon. More will be made available.
bugeyed
- Aug 16, 2013
Sorry, wasn't directed at you, just my initial reaction to the price. Thanks for the info.
kev
Arsis
- Apr 2, 2013
I feel $15 is a fair price. It is, after all, a specialty part. Anyone experienced with a soldering iron shouldn't have trouble. Proper technique shouldn't melt the plastic. I'll be ordering one.
CR0NeX
- Nov 27, 2013
Hey guys!
I've got my 598's from a local official distributor last week, and they were awesome, until... Suddenly, they started playing both channels on both sides at the same time. E.g when I'm doing a left/right test I can hear every sound on every side. Anyone else had this problem? I'm "new" to the headphone world, and I'm not sure what might be causing it. Tried pluggin them into different sources - the same.
santacruise
- Mar 15, 2012
The easiest thing to do is take it back to your local store and get an exchange
ace54
- Feb 16, 2013
i need a headphone amp for my HD 598 i mostly use it for movies S1000ES bluray player with 7.1 surround sound headphone jack but the volume doesn't go high enough so i need an amp any recommendations?
I don't want to spend too much money maybe $100.00 it would be nice if the amp has equalizer settings so i can turn up the bass a bit also i listen to pop, rap,rock music
thanks in advance
thanks in advance
Arsis
- Apr 2, 2013
Hey guys!
did you check the plug where it goes into the phones ear cup?
CR0NeX
- Nov 27, 2013
Hey. Yeah, even tried re-plugging it, still no good. I'll probably have to exchange them I guess. That's a shame, they were just getting better and better with some burning in.
K.T.
- Apr 18, 2003
thanks in advance
Please check out the Schiit Vali amp. It's $119, but sounds many, many times it's price. Many head-fi'ers agree. Sounds absolutely fantastic with the HD-598.
http://www.head-fi.org/t/685162/new-vali-schiit-amp
I recommend the Vali with the HD-598 whole heartedly.
ace54
- Feb 16, 2013
would I be able to use the Schiit Vali amp with a 3.5mm headphone to rca y-splitter adapter so i could still have the surround sound option from my blu ray player headphone jack?
palmfish
Surround sound from a headphone jack? How do you manage that?
ace54
- Feb 16, 2013
it is built into the blu ray player itself S1000ES
"7.1channel virtual headphone output
7.1channel virtual headphone output provides the ultimate personal entertainment experience, allowing you to enjoy your favorite Blu-ray Disc movie, DVD or CD through standard headphones with amazing 7.1 channel virtual surround sound.
Dolby Digital Plus
Dolby TrueHD
DTS-HD High Resolution Audio
DTS-HD Master Audio"
Dolby Digital Plus
Dolby TrueHD
Total: 21 (members: 0, guests: 21)
