Yep tried both USB and optical. It clicked and got the info from my two PCs but no sound to the amp. Amp works just fine. Tested both the red/white with different cables and balanced interconnects.
That sounds like trying different inputs on the back. Just to make sure, are you cycling through the inputs with the button on the front? If so, do you get two lights turning on to show "sample rate" while playing music?
Sorry to hear this.
As @buke9 mentioned, are you positive that the volume is not muted and up all the way on whatever music software you're using along with your PC volume?
Sorry to hear this.
OK.
I was just checking again being this has happened to me on more than one occasion, and I went nuts for nothing. Sometimes it's the smiliest thing.
Anyway, hope you get your Yggy back ASAP, and again, sorry to hear this.
OK.
