Have a Jotunheim 2 coming in. Upgrading from a magni and modi+. Will there be any real benefit of upgrading to a modius from the modi+ (besides matching aesthetics with the Jot 2)? I know Jot 2 isn't picky with SE vs. balanced input with Nexus, but has anyone had experience using both with the amp?
Schiit Modius discussion - $199 balanced AK4493 DAC
- Thread starter Mightygrey
moonfishing
Just speculating here, but I would guess, yes, there would be a very small perceptible difference. I would probably save up more for a bigger jump though.Have a Jotunheim 2 coming in. Upgrading from a magni and modi+. Will there be any real benefit of upgrading to a modius from the modi+ (besides matching aesthetics with the Jot 2)? I know Jot 2 isn't picky with SE vs. balanced input with Nexus, but has anyone had experience using both with the amp?
RugbyPlayer
- Jan 22, 2013
Hi all,
Im trying to figure out what cable i need to buy. I have a Shiit DAC/AMP (Modius/Magnius) stack that i want to use with a PS5, but from what i understand the PS5 only supports UAC1, which the Modius DAC does not. I think i can use the G6 to passthrough audio INCLUDING tempest audio correct?
So the chain would be PS5-> (USB) G6 -> (Optical - this is the cable i need) Modius -> Magnius -> HD800s.
From what I can tell on bestbuy i cant get one locally unfortunately so i need to know a trusted brand i can find on amazon.
dstarr3
Your TV probably has an optical audio output you can useHi all,
RugbyPlayer
- Jan 22, 2013
not an option, the ps5 doesnt output spatial audio via hdmiYour TV probably has an optical audio output you can use
cdacosta
https://www.reddit.com/r/PS5/comments/k0xgvd/guide_how_to_get_your_dac_to_work_on_ps5/Hi all,
Xerosnake90
I just upgraded from my Magni+/Modi+ to a Midgard/Modius E set up. I was able to compare the Modi to the Modius with the Midgard since the Midgard itself made such a sonic difference over the Magni. I'm listening with Beyerdynamic DT 990
I can't really agree that there's a "Very small" difference between the Modi and the Modius E. After some A/Bing the Modi is just smaller, flatter sounding. The Modius took an already nice soundstage and imaging and pushed it even wider. Not only that but the sound is just more full, larger, more energetic. I had in the past used a Jot 2 and when I added the Bifrost 2 it was much the same. Imo if you're going to get into audiophile gear then start go one step above the Magni/Modi into the Midgard/Modius. It's quite a difference already
TinearedOne
- Feb 23, 2015
So not balanced, right? Thinking of picking up a Midgard to pair with my 4493 Modius… to upgrade from Magni 3+.I just upgraded from my Magni+/Modi+ to a Midgard/Modius E set up. I was able to compare the Modi to the Modius with the Midgard since the Midgard itself made such a sonic difference over the Magni. I'm listening with Beyerdynamic DT 990
Xerosnake90
I connect the Midgard and Modius using the balanced input/outputSo not balanced, right? Thinking of picking up a Midgard to pair with my 4493 Modius… to upgrade from Magni 3+.
TinearedOne
- Feb 23, 2015
…but not the headphones? The Beyers are not balanced, right?I connect the Midgard and Modius using the balanced input/output
Xerosnake90
No, but I do have a pair of Amiron Home on the way with balanced so I can try out Halo.…but not the headphones? The Beyers are not balanced, right?
