BMBROWN911
- Apr 4, 2003
I'm having the same issue but have not been able to isolate it.
Zabzaf I've seen it said the circlotron topology in the mjolnir is more sensitive to ac line noise than other types. Don't know if tha'ts technically true but I also had a buzz in my mjolnir and I isolated it to the ceiling light dimmer switch in my living room . I started researching all sorts of expensive power filtering and power transformer options but I decided to just replace the light switch with a cheap on/off type and that fixed it. If yours is a dimmer you might want to try that, or maybe just install a nicer light switch and it might not have that problem. I know lutron ones are supposed to be good, their dimmer switches have built in rfi/emi filters. It's weird, right? None of my other amps had the buzzing, only the mjolnir.
I've been looking at the Mjolnir as a potential "buy", but I have to admit this discussion has been a BUZZkill for me. (intended)
So this is pretty much an anomaly? It's no more susceptible than any other amp?
