Schiit Mjolnir 3 - Impressions Thread
Apr 26, 2024 at 9:28 AM Post #2,716 of 2,846
I'd have to find a Mjolnir 3 on the used market. If it's as good as people say that may be difficult to do.
Why used? They are still being made. Just cut back on the Tim Horton's coffee for a little while :)
Apr 26, 2024 at 10:26 AM Post #2,717 of 2,846
Occasionally find them on the used market, but are selling at close to retail between $1000 - $1100
Given the relatively small price difference it's likely worth going new to have the 5 year warranty
And not that many are failing, but there seems to have been a silent revision to a few caps used on the board that could be an issue if picking up a used one
Apr 26, 2024 at 11:07 AM Post #2,718 of 2,846
I didn’t see the Mjolnir listed on the Schiit product page. I had to do a web search to find it.
Apr 26, 2024 at 9:01 PM Post #2,719 of 2,846
If anyone is looking for a fairly inexpensive cooling solution, I found the AIRCOM S6 sits over the vent nicely and hides under the shelf. Exhausts to the rear and has an auto setting to turn on at 88F and shuts off at 84F. $50 and has two 120mm fans.
Have you compared the headphone output of the Yamaha with the Mjolnir? If so what is your take on it?
Apr 27, 2024 at 3:11 AM Post #2,720 of 2,846
Some first impressions after about 24 hours burn-in:
- Truly special and good sounding SS amp. There is some sweet liquidity in the sound which is rare in SS amps. This aspect reminded me to my first encounter witht he Meze Empyrean in 2018.
- Quite energetic and clear sound but with rounded edges, so it is not aggressive. Soundstage is good but not huge, but I do not actually mind it as the space has very good depth layering and imaging. It is easy to visualise instruments in their place.
- Bass is not overblown, but strong with good impact. Mids are clear and vocals surprisingly sweet and lifelike for a SS amp. Treble initially was a little dry, and slightly too forward, but this seems to be taming down with burn-in.
- Overall, a clean, clear, dynamic, impactful but at the same time smooth and fun sound. Acoustic instrument tone and timbre is good, but my NOS tubed HA-3A is more fluid, richer and more natural when it comes to string instruments. Tubes also give vocals more magic. MJ3 on the other hand offers better technicalities with more detail, better dynamics and a lot clearer, more defined and more impactful bass. As expected, I prefer MJ3 bass but HA-3A treble. These two amps are very different and offer different strengths, a different listening experience.
- Warm up time is real with the MJ3. It takes at least an hour but more like 2-3 hours to get the hottest, but sound is best when the amp is fully warmed up. For now, I keep it on a separate, 4-inch-tall (10cm) stand where breathability is good. This way even the hottest temperatures do not seem like anything to worry about, no fan needed for me.
- Dislike that is the switch on toggle is located on the back.
- With my ZMF Caldera I prefer low gain, no feedback. Also, usually SE versus push-pull. The differences are actually smaller than I expected, but they are there. My Cyan 2 DAC puts out 5V, which is a little higher than the 4V average for XLR out. Perhaps this is partly why I prefer low gain with the Caldera. High gain is just a little too harsh. Feedback takes away a little from dynamics in a subtle but non-favourable way at least to me. I initially liked the subtle liveliness push-pull brought to the picture, but after a while it gets a little too much in the treble. Treble is already quite lively, so I prefer to leave it in SE mode.
Overall, I am happy so far: great bass, dynamic but sweet and clear, detailed sound. A fun and engaging listen with good technicalities. The relatively smaller soundstage is nicely compensated with great spatial imaging, so I am happy on that front as well. If there is one thing, I would improve that would be a tiny bit more relaxed and more natural treble, but that will probably improve with further burn in and I am used to tube amps these days which have liquid treble.
So, I like the MJ3, but let's see where things lead and evolve. :)
Excuse me for replying to my own post, it is not a symptom of losing my mind, I just thought instead of editing it is better to update this way to keep the line of thoughts consistent and help folks who follow the conversation not to miss this correction. :)
I just thought I owe the HA-3A with this update. When I wrote the above post, my DAC was using coax input from my streamer and not the better USB input. Apparently, some system noise is creeping through coax connection which affects my tube amp more than the SS amps. USB is galvanically isolated, and it is dead silent, resulting in a much cleaner and clearer sound overall. With coax connection between my streamer and DAC the HA-3A sounded warmer and hazier than it should, but with USB input everything clears up tremendously. (Yes, easy to get a bit lost when you have been A/B comparing amps for hours. :) )
Anyway, by using USB on my Cyan 2 the technical differences basically disappear between the HA-3A and MJ3. By that I mostly mean detail retrieval and clarity. The difference in bass rendering also becomes smaller. I must say though, this is only true with the good NOS tubes I use and not with the stock tube set. (I use GE rectifier, Bendix 6V6 and Mullard 12AU7.) The MJ3 still has the edge in bass speed and impact, but the 3A does it in a satisfying enough way too. From upper-mids upwards the tubes just sound richer and fuller offering more natural tone and timbre. The Cayin is also a little more spacious.
The 'battle' is still ongoing, soon joined by the Mentor, I just thought I owe my trusty tubes with this little correction.
Apr 27, 2024 at 8:48 AM Post #2,721 of 2,846
Will the M3 run Atrium Open satisfactorily? Also the Caldera? I calculated following values for the Atrium Open at Schiit stated values for power at 300 ohms, 1W per channel, 17.32 volts, 57.7 mA current draw.
Caldera: 1.067W at 60 ohms, 8.012 volts, and 133.5 mA current draw. Assuming I calculated these values correctly LOL.
So synergy wise, would the Caldera be the better match for the Mjnolnir 3 amp? Does M3 handle planar drivers better with higher current draw vs. voltage supplied? Output impedance less than 0.25 ohms on M3 amp. V281 can supply 40 volts to Atrium Open. Dynamic drivers need higher voltage, planars need higher current, is this generally a correct assumption? This is not not even getting into tube amp specificity with OTL vs transformer coupled output.
What brought all this up was reading how kick-ass the V281 amp is with the Atrium Open, and I had originally wanted to get that headphone until researching the Caldera more in-depth. Thoughts on synergy between M3 and these two headphones? I have no intention of switching out amps after I just got M3. This just points out how important it really is to consider synergy between amp and headphones BEFORE LAYING OUT THE CASH.
Apr 27, 2024 at 12:36 PM Post #2,722 of 2,846
The headphone amp on the Yamaha isn't bad, I haven't played with it too much however. It has 50mw+50mw so not particularly powerful. For my easy to drive dynamic stuff it works fine and I like the tone controls and handful of gain options. The Mjolnir sounds more open/better staging to me and I like the sound of my Empyreans better on it than the Yamaha. As a speaker amp though I love the A-S2200, zero regrets, but the headphone amp on it is just satisfactory.
Apr 27, 2024 at 2:59 PM Post #2,723 of 2,846
... I calculated following values for the Atrium Open at Schiit stated values for power at 300 ohms, 1W per channel, 17.32 volts, 57.7 mA current draw.
How did you calculate these? I want to do the same for my Sendy Aiva: 32 Ohms at 96 dB per 1 mW, which, amusingly to me, one reviewer said: By far, the best match was with a 16-Watt Flux Labs Acoustics Volot and FA-10.
As a planar, the Aiva needs current?
Apr 27, 2024 at 3:19 PM Post #2,724 of 2,846
Using ohms law and power equations with given values where available to solve for unknowns. Trying to triangulate info from different sources to better understand synergies between M3 and Atrium open vs Caldera.
Apr 28, 2024 at 12:44 AM Post #2,725 of 2,846
for Sendy Aria, rated at 96dB/mW:
for the same volume level, 93dB/mW cans will need twice the power, and 90dB/mW ones will need 4 times the power vs Sendy Aria.
only 1/1000 Watt is needed for 96dB (for reference, a residential smoke alarm is 85dB min per Code requirements), and perhaps only 100mW is needed to produce lower bass approaching the LF response fall-off of the HP's.
The pairing recommendation with Flux Volot or FA-10 is more likely due to complementary tonal matching (warm bass heavy amp with mid-and-upper-forward Aria) rather than absolute amplifier power. Perhaps the Aria are of similar sonic signature to my bass-light AKG K702's...
@commtrd your numbers for voltage and current look good. Jason mentioned here about MJ3's max power (3-4 Watts into 64 ohms), so should be more than ample power for Caldera at 60 ohms and efficient at 95dB/mW.
https://www.head-fi.org/threads/sch...bable-start-up.701900/page-8254#post-17692519
SPL (dB) power-wise (watts) = 10 * log (n). and Voltage gain is 20 * log (n). e.g. voltage gain of 2 is ~6.02dB, power gain of 2 is ~3.01dB
96dB/mW cans need only 10mW for 106dB, 100mW for 116dB (if they don't reach dynamic non-linear compression before this point)
Apr 28, 2024 at 1:50 AM Post #2,727 of 2,846
MJ3 only needed to go up to 12 o clock for my Susvara. Unfortunately it didn’t jive well on certain genre and songs so I ended up getting a different amp. However, it’s amazing on dynamic headphones hands down so I kept it.
Apr 28, 2024 at 12:17 PM Post #2,728 of 2,846
... Perhaps the Aria are of similar sonic signature to my bass-light AKG K702's ....
Thanks! I don't find the Avias bass-light for my genres (classical, jazz, 80s rock). Judging by Telarc's 1812, my bass is good enough. Sometimes I fear the drivers will pop right out.
I can imagine more bass-heavy music not being served well.
I happen to know that I listen to music maybe 10dB quieter than most headphone users; the one meet I attended I came away thinking, "These people will all be deaf by the time their 35yo..." Here, in my end-game-ish 2ch setup, with a residential noise floor in the low 30dBs, listening to this song, I'm getting 56db avg/70dB peak, which is perfectly satisfactory. Somewhat louder would be nice but then I'll have the added noise of other residents complaining :wink:
All these numbers guys. The MJ3 is able to drive 98% of all headphones. The question you should ask is about synergy and not power.
(For reference, with my Caldera I never pass 11 o'clock on the MJ3 using low gain.)
For me, listening to Shirley Bassey's Diamonds Are Forever, maybe, I'd go to 10:30, to block out the world....
Apr 28, 2024 at 1:08 PM Post #2,729 of 2,846
It's not about the numbers at all. Just a tool to try to optimize the synergy BEFORE spending the money. Since great quality gear is very expensive. Trying to understand what technical factors play into optimizing the entire chain of components, but it's all about the synergy with all the components from source to headphone to get it right the first time.
For instance, I now understand that the Atrium is going to be better driven by an amp with a higher output impedance. Somewhere down the line I want to get a really good transformer coupled tube amp and another MiB dac to be used specifically for Atrium Open. And keep my current stack for a Caldera. THAT will be my end game. I want to get a custom built Caldera and that will be my new daily driver headphone.
Apr 28, 2024 at 1:48 PM Post #2,730 of 2,846
'Optimising synergy' before purchase is like picking your partner for a date based on hight, weight and chest size. Only takes you so far. You will only know about real synergy once you had a chat with the lady or audition the gear.
