Hm. I disagree. This holds up for me.Early reports corroborated on various other forums is this is very much an introductory amp, which is obvious, but Schiit has made a reputation of punching way above their weight and price point. Magnius, however, very much shows its introductory flavor. It lacks harmonics and liquidity, and can be dry and cutting at times.
Buy this amp if you want to explore the ground floor level of balanced amps, but don't be tricked into thinking it can compete with bigger boys, which Schiit has previously made a living doing before. Don't get caught in the mid-fi side grade loop as it's different, but probably not better. A few people have said Magni 3+ and Heresy are better than this when using SE. If you have them, you're already better off. If you have Jot, you're also better off.
For reference, I'm a huge Schiit fanboy and own a bunch of their gear. I recently acquired Modius, and it punches way above its weight, and it's uncomfortably close to Gumby. However, I'll be sitting this round out with Magnius.
Also only balanced.
