Just one question, does it click every time or just few times between songs when I connect Gungnir/Gumby to my computer through USB?
Thanks!
Only when sampling rate is changed or you sleep/ awake the computer.
Thanks!
So it won't click when I play 10 songs from the same album?
Thanks a lot.
Thanks a lot.
I assume there is some delay too when switching sample rates? Is the clicking obnoxiously loud? I skip through tracks with different sample rates a lot so that could be a small inconvenience.
The DAC should only "click" when the sample frequency changes from one track to another.
While I can't answer your question exactly, I had Lyr 2 and Bimby and upgraded to Yggy.
The change was much more subtle than either when I swapped Lyr 2 with Mjolnir 2 SE and or when I then went to Balanced.
The Gumby is a mighty fine DAC, balanced or single ended. Whether or not it's worth the added cost to you will of course depend on your ears, your equipment, and how important this stuff is to you. If you can swing it, I'd say go for it.
Was it a worthy improvement to go from Lyr 2 to Mjolnir? And from Single End to Balanced?
