Lorspeaker
- Nov 29, 2010
Do you have balanced headphones? If so, which ones?
none at the moment.
If not, are you looking at balanced headphones or a balanced amp in the future?
reading up on some german gears..thoroughly confused..hehe
For balanced headphone output, how important is it to have dual three-pin XLRs as well as a 4-pin XLR?
i guess the one that has superior sonic qualities, and i will just stick with that.
For a balanced amp, how important is it to also have single-ended outputs?
that would be a PLUS definitely..so tat i dun have to recable a new can..before i decide to keep/sell it.
If single-ended is important, is the quality of the single-ended outputs as important as the balanced outputs, or is this more of a “utility” thing so you can use all kinds of different headphones?
i think the point of getting a balanced amp is to blow my mind off...vs a single-ended amp...there must be a clear superiority in soundstage, seperation, clarity..say 20-30% better,
when u switch from the single-ended to the balanced output on the same amp. otherwise i would just stick to a regular amp.
none at the moment.
