Nov 25, 2010 at 10:14 PM Thread Starter Post #1 of 7 ProjectDenz Headphoneus Supremus Joined Aug 1, 2010 Posts 1,647 Likes 74 Just wondering if anyone knows the difference in sound quality between the two. While the s:flo2 has a LO, I will never use it.
Nov 26, 2010 at 12:46 AM Post #2 of 7 ClieOS IEM Reviewer Extraordinaire Joined May 11, 2004 Posts 21,324 Likes 12,388 Location Mid Johor, Malaysia I don't think s:flo (T50) is SQ oriented. S:flo2 (T51) is Teclast first SQ oriented DAP.
Nov 26, 2010 at 1:06 AM Post #3 of 7 ProjectDenz Headphoneus Supremus Joined Aug 1, 2010 Posts 1,647 Likes 74 Oh, so I am assuming that it will sound worse than a rockboxed sansa clip then?
Nov 26, 2010 at 6:22 AM Post #4 of 7 ClieOS IEM Reviewer Extraordinaire Joined May 11, 2004 Posts 21,324 Likes 12,388 Location Mid Johor, Malaysia Quote: projectdenz said: Oh, so I am assuming that it will sound worse than a rockboxed sansa clip then? Click to expand... Won't presume to know how they compare since i have heard none.
Nov 26, 2010 at 6:47 AM Post #5 of 7 kiteki aka Theta Alpha 1aka Alpha Zeta 5aka Alpha Zeta 6aka Nanocat SystemsAnd many other aliases Joined Jun 7, 2010 Posts 10,617 Likes 174 Quote: projectdenz said: While the s:flo2 has a LO, I will never use it. Click to expand... Oh yes you will
Nov 26, 2010 at 10:37 PM Post #6 of 7 ProjectDenz Headphoneus Supremus Joined Aug 1, 2010 Posts 1,647 Likes 74 Quote: kiteki said: Quote: projectdenz said: While the s:flo2 has a LO, I will never use it. Click to expand... Oh yes you will Click to expand... Ok, thanks ClieOS. Oh, no I wont - amps just don't provide enough price/performance ratio to convince me to buy a good one - aka tightass.
Nov 28, 2010 at 12:04 PM Post #7 of 7 kiteki aka Theta Alpha 1aka Alpha Zeta 5aka Alpha Zeta 6aka Nanocat SystemsAnd many other aliases Joined Jun 7, 2010 Posts 10,617 Likes 174 Quote: projectdenz said: Quote: kiteki said: Oh yes you will Click to expand... Oh, no I wont - amps just don't provide enough price/performance ratio to convince me to buy a good one - aka tightass. Click to expand... You can listen to the line-out with your earphones. At $140 the Teclast T51 has the best price/performance ratio I've seen in a while.
