the_eleven
- May 15, 2008
I could be listening to a Predator mature, but instead I am waiting for the R-71a.
Originally Posted by wavoman /img/forum/go_quote.gif But let's add: Ray is a pleasure to do business with. No waiting list. No guessing on when you will get your amp. He phones you! He checks if you are happy! Amazing. |
Originally Posted by wavoman /img/forum/go_quote.gif I use the amp only (no need for the DAC), and it really is as good as everyone here says, especially after burn-in. You are reading the truth, not groupie fanboy prattle. I have Ultrasone Pro 750, Beyer 600-Ohm 880, and Senn 600 (closed, semi-open, and open). Drives 'em all, and drives me wild (and drives my wife crazy, 'cause I sing and dance while listening, and I can't do either, I actually look and sound like a buffoon, but who cares). Source is a Cowon I7, all wav files ripped using EAC, custom red-and-black Predator to match the I7. But let's add: Ray is a pleasure to do business with. No waiting list. No guessing on when you will get your amp. He phones you! He checks if you are happy! Amazing. |
Originally Posted by the_eleven /img/forum/go_quote.gif I could be listening to a Predator mature, but instead I am waiting for the R-71a. |
Originally Posted by The Monkey /img/forum/go_quote.gif What are you guys using to measure burn-in time? Is a digital clock more reliable or is analog better? Thanks! |
Originally Posted by gp_hebert /img/forum/go_quote.gif I bet some people will tell the same burn-in BS with the SR-71 so you better get a Predator now if that's what you want. Listen with your ears and don't believe the hype. |
Originally Posted by user1029 /img/forum/go_quote.gif I wholeheartedly agree. Unless there is a unanimous, unequivocal consensus that the SR-71 revolutionizes the current landscape of portable amps, I'll stick with my Predator. Portable amps have decent resale value as well |
Originally Posted by jamato8 /img/forum/go_quote.gif Is the body red or black? |
Originally Posted by jamato8 /img/forum/go_quote.gif do you look like Snoopy when you dance? |
Originally Posted by the_eleven /img/forum/go_quote.gif The Predator is highly praised by everyone; no doubt it is a fine amp that I would be very happy with. I suspect that Mr. Samuels is up to something good, so might as well wait until the 71a arrives. |
Originally Posted by Icarium /img/forum/go_quote.gif That's a pretty loose definition of "everyone" |
Originally Posted by jp11801 /img/forum/go_quote.gif here is where you guys are off base, caps require power cycles to form. Leaving you amp on 24/7 does not effectively form your cap as there is no power cycle on them off with rest. So basically this is most likely a case of mental burn in combined with your head compensating for your expectation. It would be a great idea for folks to read up and educate yourself prior to making claims like these. Once again big caps in small amps that "require" 1000+ hours of burn in by members that don't even understand cap forming should be taken with a giant sized grain of salt. Just curious why would an amp manufacter include a cap in a design that is so out of spec with the voltage/current that the amp produces? Bueller? |
