nipit
- Sep 1, 2011
Guys, how would you compare ROCOO P to T51, Hifiman601?
Could you please tell a couple of words about this player?
A little bit detailed answer would be considered as better comment.
lee730 You told that you haven't even heard this player, how can you compare it? Forgive me if that's wrong information that I have but if this is true you can't really compare things that you haven't heard.
Thanks for your reply. Too bad I missed Studio V for 175$. Guess I'll settle down with Rocoo P. Will player handle 12 Ohm earphones without problems? Or there is going to be hiss?
I'm not sure about that. Chime in with someone with the player. But my Studio V does have some hiss. I ordered an ohm adapter to eliminate any hiss. The Chinese sellers on eBay sell them and can customize the ohm resistance to accommodate your IEMs. Just you'd have to figure out the output impedance of the Rocoo P to be sure.
...The only thing ClieOS said was that the bass on the T51 has more bass impact. Which is no longer the case with the updated version of the Rocoo P. (a headfier confirmed this)....
There is an updated version of RoCoo P? I don't think I have read about it in anywhere, not even from HiSound's own forum.
what he meant is firmware update
