headwhacker
- Sep 4, 2013
Still can hear some cracklin, just qieter. I'm not sure about continous play, but there is some crackling for couple seconds after manualy switched tracks.
At this point, you have to closely discriminate the actual noise produced by switching tracks and the background noise in the tracks itself. I got a couple of gotchas myself but it turns out it's the noise coming from the track.
At worst, I only get a quick and soft click when switching tracks at the beginning. But not the noise that last a second or longer like what I can easily hear before. I still have not heard the noise while listening to a long playlist or album.
When I test switching tracks in this case I press the prev or fwd button once or twice . In this scenario I have not encounter any noise yet and imo is the best representation of a normal usage.
Also, if you are going to press the prev or fwd button in a very quick succession you are repeatedly forcing rockbox to dump and fill the buffer which increases the chance of hearing a noise. Still not as loud nor last as long as can be heared before.
If you are using a c/iem, a slight movement of your jaw can produce a similar effect or noise so you should be aware of it as well.
