Well,
I have installed the RockBox firmware, its very nice and god i love its equalizer,
i updated the database (had problems updating it, but then i went to Database in settings and chose the folders to synch, then it worked ok) but anyway i dont use database, i use file explorer and its working ok.
created playlists .. OK
the touch screen is working in absolute point mode by default where you can access anything by directly pressing on it.
it can be changed to grid mode from the settings which i think divide screen to 3 parts horizontally (up/ok/down) and didn't like it.
on the now playing screen :
top left corner goes to main menu while song is playing /
top right corner goes to current song in file explorer while song is playing /
bottom left corner goes to repeat and shuffle options while song is playing /
bottom right corner i think goes to the current playlist while song is playing /
middle pause and play / left previous song / right next song.
so far so good ..
need to shutdown from the menu as power button doesn't shutdown.
the only question that is driving me bananas , are they both built on the same sound library, meaning with EQ off, rockbox gives same sound as 1.2.8 ??
because i keep switching between them and sometimes i feel they are the same, and sometimes i feel 1.2.8 is a bit more airy, and i really need to get this out of my head, so that i can enjoy the rockbox software
also is the touchscreen actions, theme related ? meaning different themes need to be adjusted for touch ?
Sorry for making it long..
so far so good ..
