7S Cameron
Does anyone know where I can get the iBasso rkbatchtool? The link in the OP isn't working and I can't find it on their website.
There are 2 links to it in the OP - the first one is working.
BTW, I wanna share some information to rb developers I found recently. I think it would be helpful.
here is Mango 1.5.0 source code - https://github.com/liuwenlong/my-linux-gui
Pretty sure it can be used to fix some issues, like battery level, https://github.com/liuwenlong/my-linux-gui/blob/work/apps/player/playingView.cpp#L598-L612 or improve usb dac implemenration/etc
The first thing that ArgelErx did now is getting rid of the separate vold files for rockbox/mango. This was one of the few remaining steps to make the installation procedure conform to open source license.
Until now, the vold file used by rockbox was the same like the one from the official firmware but binary-patched by Ilia (it was great to have this solution until now, thanks Ilia!). For more information about it contact me or ArgelErx.
Now for those who would like to help testing it:
New experimetal dualboot app:
- tested by me and ArgelErx, but I would be happy If some more stability testing could be done by .......(you?)
- what you need: FW 1.6.0 with cwm (with or without rockbox preinstalled)
- Installation procedure: install zip from cwm
- benefits using the new dualboot app (other than testing): if you switch between Mango/rockbox there is a MUCH smaller boot-delay!
Download: https://www.sendspace.com/file/h4ceki
Edit: please test the newer version "patchset 3": https://www.sendspace.com/file/5xyjdj
How does this benifit the user? I dont know much about how Rockbox works.
with testing you can help to find potential bugs. When a bug report leads to a bug fix at the end, everybody benefits.
Can I install this latest build on a cwm'd 1.5.0 as well? (I prefer the way it sounds with my current phones)
I'm assuming there should be no problems, but this is my first leap to rockbox on DX50, so I figured I'd ask first; have used it on other devices though.
Also, does this build (or is it possible to get a hold of one) include modern_ui?
Seems like a really smart patch, (dare I say this functionality might be useful enough to somehow be implemented in other ports as well; maybe if it was toggleable through settings RB devs might respond to it better, hmm..?), so I'd definitely like to have it!
Thanks for all your hard work everyone involved! Been following the progress on this port every now and then.
edit: hmm.. I realize the boot files might be different, so.. I'll hold off for now.. Better safe than sorry.. Just might go ahead with installing an earlier build though..
Or hmm.. I guess I should use the old dualboot app with latest RB build.. Should have held off posting before processing the info myself properly.. The role of the different parts is becoming much clearer to me now.. Well it was clear already somewhat, I was more confused by which things get flashed together, seems like this changed at some point which lead to my confusion.
